Which replacement siemens breaker do I need? | on ElectriciansForums
Discuss Which replacement siemens breaker do I need? in the UK Electrical Forum area at ElectriciansForums.net
seffzero
colorado
The breaker pictured trips with nothing plugged into the circuit. It is able to be reset and stays reset for several days, but trips again. When resetting, It is slow to do so and does not snap into place like the other 15 amp breakers pictured leading me to believe it has failed. I have searched for replacements and visited local retailers and gotten conflicting answers concerning compatibility between QAF/QAF2/QAF2N. What replacement breaker do I need?
  • [ElectriciansForums.net] Which replacement siemens breaker do I need?
It appears to be a Siemens type QAF. Just remove the breaker and take it to Lowe’s or Home Depot and make sure they have a breaker that matches yours. Worst case go to your local Electrical Supply Store with the breaker to make sure they have the proper breaker. Good luck and welcome to the forum.
Reply to Which replacement siemens breaker do I need? in the UK Electrical Forum area at ElectriciansForums.net
Your primary concern here is the service wire being #8 aluminum, which, as you mentioned, is typically rated for 40 amps. For a 100 amp panel or...
It would be helpful if you took a picture of the back of the breaker so we could tell how it snaps in. Normally a GE breaker type THQL will work...
Hi Darkwood, Thank you — I think that is spot on !!! David
Thanks. I presume it’s okay to be pedantic given that I’m not working with 9V batteries. To be clear, I’ll double, triple and quadruple check...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
