Wire extractor fan to bathroom pull switch | on ElectriciansForums
Discuss Wire extractor fan to bathroom pull switch in the UK Electrical Forum area at ElectriciansForums.net
uk
1964 house old style wiring
Need to wire a extractor fan up
Is it possible to wire the extractor fan to report switch there's 2 red wires in the pull switch both red. one is a permanent live
Can I wire it up to the pull switch some how or do I need to go to the ceiling rose wiring which is in a very awkward place
any help would be appreciated appreciated sailing rose which is in a very awkward place ceiling rows which is in a very awkward place any help would be appreciated
  • [ElectriciansForums.net] Wire extractor fan to bathroom pull switch
You are lacking the neutral so would probably need to goto the ceiling rose.
It’s doubtful your going to find a switched live at some junction box it’s going to be at the ceiling rose.
The best way of wiring a timed extractor fan is use a 3 core+e from the rose to a 3 pole isolator switch feeding the fan
Thank you all I think your all right ill have to get into the ceiling rose bit of a pain in the bum right under the Eve's but hey ho
Thanks to everybody that replied I'll post another picture when I get to it
Yes you will.
There was a time when houses had a central joint box under the landing floor for downstairs, and one in attic, right at the hatch, for upstairs.
If wired in twin and earth of course.
There was a feed from mains, and a twin running out to every switch, and a twin out to every light.
One big connector with all the lives, another for neutral and a massive one for earths.
and a handful of switchwire connections from each room switch to corresponding light.
Great care not to get those mixed up or bedroom 1 switch turns on the light somewhere else. 🤣
Yes you will.
Tis
Yes you will.
This is what I found
Yes you will.
That would mean you would only have 2 + e at each ceiling rose, this doesn't seem to be the case with OP.
Tis
Looks like someone has removed the rose and choc blocked it.
A typical thing that's done when putting up a light fitting that won't cover the ceiling rose.
The cables need to be in a proper enclosure.
If a electrician sorts that wiring
Does any body think it be compatible with a extractor fan that has a fan overrun on it
( continues to run after light switched off for a while)
Reply to Wire extractor fan to bathroom pull switch in the UK Electrical Forum area at ElectriciansForums.net
I'm familiar with many domestic extractor fans which are primarily class 2 (double insulated) and consequently are not required to be earthed...
I think you are going to need an electrician because it looks like someone has used the bare earth (has been sleeved black) as a live conductor...
Rcd protection?
Thanks for your advice guys. very helpful
It would normally be the outer terminals where the flex of the pendant drop connect.
