Switched Neutral Fault Finding | on ElectriciansForums
Discuss Switched Neutral Fault Finding in the UK Electrical Forum area at ElectriciansForums.net
DyFamCont
Trainee
Lincolnshire
Evening all,
I had a quick Friday afternoon domestic job that has turned into a PITA and I'd appreciate your help.
While adding some new lights to a circuit, I found that the switch where I was taking the additional line from was actually switching the neutral. After much swearing I checked the polarity at the ceiling rose and got some odd results from the ceiling rose as per the table below. The part that's confusing me is why N-E is at 230v with the switch open.
Being a domestic job, I can't follow the cables properly without wrecking the place but have done continuity to find out what each goes to. The camera in the ceiling revealed nothing of significance. I'm assuming there's a junction box somewhere in the middle where someone has messed it up. The rest of the lights in the circuit have the correct polarity.
Any help would be greatly appreciated because I said I'd go back tomorrow.
[ElectriciansForums.net] Switched Neutral Fault Finding
sure im not going mad but them readings are as they would be if the neutral is switched, so looks like you need to extend the feed so the line an be switched, and put a blank plate on the existing switch !
Reply to Switched Neutral Fault Finding in the UK Electrical Forum area at ElectriciansForums.net
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
ok cheers for the help lads
SOLVED Thanks for all the help. It was nothing to do with the smoke detector. In this new hole (where there will be a light fitting) three white...
Ok, please be aware that I am a 'do-it-yourself-er,' so if this isn't the right place to be posting this thread, let me know where I should be...
When you did the further testing and got the 0.06 reading were the CPC's back in the consumer unit? Really when testing you should leave the...
