Heating programmer help please....? | on ElectriciansForums
Discuss Heating programmer help please....? in the UK Electrical Forum area at ElectriciansForums.net
sussex
Hi Guys
Changing my heating/water programmer and im stuck on the wiring ive gone from a danfoss to a Drayton and the wiring description is different ive had a go at what I think is correct but now when the heating is on and hot water off the hot water is still calling, and when I have just hot water on the heating comes on also. Ive attached a couple of pics of the old one and new one can anyone tell me which numbers on old ones go where on new one.
Thanks in advance..
Peter.
  • [ElectriciansForums.net] Heating programmer help please....?
Yes, gravity mode is not used much now, (thank goodness) it was for old systems where the hot water from the boiler convection circulates to the hot water cylinder through large pipes, without the need for a pump. The pump only being used for pushing the water through the radiators. This is not an efficient system design and many systems rely on the boiler thermostat to set the hot water temperature.
All the link does in gravity mode is ensure the hot water relay is switched on all the time the heating relay is on, or the heating pump would run without the boiler being switched on.
In fully pumped mode the hot water and heating relays operate independently.
Reply to Heating programmer help please....? in the UK Electrical Forum area at ElectriciansForums.net
glad it was such a simple fix..... And good job the previous owners didnt take it with them
I have just looked at the wiring diagram on line and there are a lot of internal links which if in the wrong terminal could put 230 volt onto...
S
Electrician Boiler Fault Boiler Fault I’m hoping someone can help with this boiler problem. Couple have just moved into a house that has a Grant...
S
This is an RSS feed of thread: Why do I have no hot water? Please help Content of the thread: Hi About 8 years ago the valve under the sink...
