Hi, my friend is having a floating shelf with a electric fire, and I’m between minds where to put the socket,
I was gonna put the socket behind the fire which will be fed by a 13A fused spur but I’m having second thoughts about putting a socket behind there due to heat..
Would it be safe behind there, or would you suggest running the cable to the cupboards to the left or right? Thanks in advance
I’ve attached picture of something similar to what it’ll be
