Since the deco needs doing to this property.
My sister needs the TV putting on thr wall but wants the cables hiding.
What will be the best way.
You can see there's a socket on one side and near it on the chimney breast is a fused switch.
I tried knocking on where the fire place has been filled. It's not hollow. I feel its brick behind there.
I would have just put a PVC trunking cover the cables. But the vent is causing problems.
Any tips would be smashing.
/ 3
