JagSingh
Has anyone used or fitted this type of back box ? It is a 1G & 2G
Discuss Hi All. 1 gang & 2 gang 35mm back box in the UK Electrical Forum area at ElectriciansForums.net
Yes, they're fine, and useful. For some reason there are only 2 (diagonally opposite) fixing holes, but you can always drill more if one or both of them line up with crumbly substrate. None of the lugs are adjustable, so you have to get the box spot-on level.
I have a feeling that if they did have adjustable lugs on either side, then any adjustment would leave the accessories slightly out of line with one another.Always wondered why this was the case with dual boxes - shouldn't be a great hardship for manufacturers to place adjustable lugs on either side.
Reply to Hi All. 1 gang & 2 gang 35mm back box in the UK Electrical Forum area at ElectriciansForums.net
