Cable size for commercial extraction fan | on ElectriciansForums
Discuss Cable size for commercial extraction fan in the UK Electrical Forum area at ElectriciansForums.net
barisk
uk
Hi , I’m going install a commercial 450mm extractor fan , what size and type of cable should i use ?
[ElectriciansForums.net] Cable size for commercial extraction fan
Need to know more than the information provided and if you don’t already know not sure you should be installing it in the first place.
As the above reply said, need the type of system installed back to the dno/fan power rating/distance between ccu and fan etc
Reply to Cable size for commercial extraction fan in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I'm looking for recommendations for a kitchen extractor fan with a rate of 60l/s. We're nearly done with our renovation, but we've just...
dimmi1975
The tighter rules came in around June 2022. I think you summed it up nicely. My understanding is that a competent electrician could install...
