Dodgy trade pictures for your amusement! - 1 Million Views! | Page 526 | on ElectriciansForums
Darkwood
Like this, found last week...?
A little depressing when you see stuff posted on here as antiques, that you've fitted as new.
Later versions of these switches has similar switch mechanisms inside to modern plate switches, but earlier versions had a totally different underslung over centre mechanism that gave a fast make and fast break, which was suitable for switching DC as well as AC.
New extension and old house refurbished. Builder moved service head himself and made the access hatch sooo small everything is inaccessible. Electrical work was done by a sparky 😳 Cable outside on the roofing tin was found to be live and just taped up.
Builders had a melt because the works been callled out!
OK I will bite, what are those grey oblong terminal blocks above the RCBO's, not part of them as they don't line up, been out of the game for a while, I know the orange thing on the right, but those blocks are a new one on me. (surge protection maybe ?)
Aren't they just tall RCBOs?
Slight angle from centre of the photo.
You live and learn, eh.;)
What’s that small one in the middle with the white push button? ;)
