Discuss Test the (RCD) Residual Current Device or die in the Lighting Forum area at ElectriciansForums.net
At least here some facilities have also fake signaling indications..... It does not matter if you are a rookie or a high experienced electrician, always rely on your instinct and knowledge first and afterwards to the signals and labels.Im not sure it may not be an official schneider label ,with the other problems i found here like a cpc used as a switch live. Probably not the best installler
Reply to Test the (RCD) Residual Current Device or die in the Lighting Forum area at ElectriciansForums.net
