Hi,
I have installed a new I lumos smart light switch it's a 4 gang switch. The switch has 2 modules that control 2 lights each. When my LED downlights are in the the same module as any other light it causes the other light to flicker. Does anyone know why my LED downlights are causing the other lights to flicker I have tried my dining light with LED bulbs and when my downlights were on my dining light would flicker. I swapped my dining light with my under cabinet light and it stopped the flickering on my dining light and started flickering with my cabinet light. All lights are on same lighting circuit. Only difference is the smart module. I know LED lights can cause issues with frequency. When I turn the downlights off it stops the flickering.
TL;DR
LED downlights in a smart light switch causing other lights to flicker
How is the switch powered? Does it have a neutral connected to it or is it powered another way?
Tumber92
I lumos light switch
Talk Electrician Forum
luketum92,
luketum92,
