Hello everyone,
I'm currently making a table lamp out of driftwood found on the beach.
Does anybody have any ideas about the cable passing through the 10mm threaded rod regarding grommets.
I'm wondering whether I should use 3/8 BSP to 15mm plumbing connection to get me into a wider diameter.
Rope cable is rated at 700w so the bulb will be nowhere near that amount.
Any help here would be greatly appreciated!
I've attached some pics and thanks in advance.
