E
easygoingchap
Hello all,
I'm a new member, so thanks for reading and any replies are appreciated.
I have been asked to replace a couple of 150W halogen fittings on the outside of an office building. The fittings at the moment are being controlled by a PIR.
I have recommended replacing halogens with 2 compact fluorescent fittings controlled via a photocell with an override switch inside.
However, the client is insisting on keeping the PIR.
My question is this: will the compact fluorescent fittings operate OK on a PIR? I was always under the impression that they didn't like being switched on and off like that. What would you recommend?
Thanks for any replies, great site btw!
