Solar Engineer Tool Kits - TMPV Series by test-meter.co.uk | on ElectriciansForums
Guest viewing is limited
Discuss Solar Engineer Tool Kits - TMPV Series by test-meter.co.uk in the Electrical Engineering Chat area at ElectriciansForums.net
F
Former Sponsor TM
Hey guys,
We've been really busy trying to get you guys a good deal on Solar Test Equipment, I'd like to think that we've hit the nail on the head! I introduce the TMPV Series:
With Solar generation rapidly growing, TMPV Kits have been designed specifically with Photovoltaic Installers in mind. These great kits will give you the quality tools needed to pass your MCS Training. Depending on which kit you choose you will be able to measure solar irradiance, crimp and tighten MC4 connectors, crimp and insulate MC3 connectors, check angle of inclination, measure solar panel temperature, analyse DC current, safely connect a multimeter or voltage detector to a PV system and correctly label your installation.
[ElectriciansForums.net] Solar Engineer Tool Kits - TMPV Series by test-meter.co.uk
TMPV1
includes:
1 x Solar Irradiance Meter
1 x Metrel MD9230 (AC/DC) Clamp Meter
1 x Custom foam lined case
TMPV2 includes:
1 x MC4 Crimping Tool
TMPV3 includes:
2 x Packs of Solar Warning Labels
TMPV4 includes:
2 x MC4 Solar Spanners
1 x Set of MC3 Crimp Dies
1 x MC3 Assembly Tool
1 x IR50 Infrared Thermometer
1 x MiniPro Digital Protractor
1 x Set of MC4 Solar Jump Leads
We have the kits in stock and are offering an additional 5% off to all forum members. We can also offer further discount for volume orders, please call 0113 248 9966 for further details.
@GraemeHarrold
Did your irradiance and clamp meter come with test certificates?
Both the MD9230 Clamp meter and the TM206 irradiance meter are supplied with certificates of conformity as standard within the kit. If you would require personalised calibration certificates with them, we can arrange that but this would be at an extra cost.
So we've got a job coming up with string voltages of up to 888V according to Sunny design - we'll need a DC voltmeter to test the arrays - any ideas please?
(Or do I have to dig my old bacolite Avometer out of the garage! ;) )
Here you go 1200VDC !! (Just don't touch the terminals!)
Thank you test-meter, ordered a new multifunction tester on friday and i have it here on monday!
Went for a Metrel mi3000, used to using Megger but fancied a change.
Amazing value for this tester, comes with everything you would expect and a bit more, rechargeable ability which is smart!!
just under £400 with cliberation certs and a 3 year warranty.
It is a solid bit of kit and i'm really chuffed to bits with it
Thank you
Bob
Reply to Solar Engineer Tool Kits - TMPV Series by test-meter.co.uk in the Electrical Engineering Chat area at ElectriciansForums.net
