Turned up on an install today, roofers were just starting so I finished the electrical install before the panels were fitted.
worked out + & - so when they were done they could plug in and turn on.
Got a call then couple of hours later saying system started up and running fine but then they used power in the garage where I installed the equipment only to find out that the board in the house was tripping.
Info is a bit vague but roofer says he turned the system off so the customer would not have problems tonight.
I gotta go back tmrw but its an 1 and half hour drive. I took the supply from the load side of the RCD in the garage CU.
See attached photo and any Idea`s would be appreciated?
