C
chrissysmagicbo
i have read that the above plate is suitable for adding a hardwired cable of 4mm for the 6kw hob and 2nd cable to a separate socket for the plug in oven which is 2450w, 13amp. do i use 4mm cable from above easyfit plate to the 13amp socket.? help is appreciated. tony 2
