brucelee
Hi all
I would be grateful if someone could give me some pointers on decking lighting
My Brother has had a large shed /workshop built
I have dug a trench 600mm to the shedabout 34m approx and installed 6mm 3 core swa in ducting to supply 4 metalclad double sockets using singles in conduit and 2 vapourproof fittings again in 1.5mm singles in conduit and a outside bulkhead over the door
i worked the volt drop out of the swa and its 5.2v this is using 21A as load for 20A for socket circuit 20Acb and 1 amp for the lighting protected by 6a CB
the length of runs for the sockets and lighting is approx 10m
the volt drop on the sockets is approx 3.6v so added to the swa volt drop gives 8.8v
the volt drop on the lighting is 1.2 rounded up so 6.4v just under the 6.9v max
I wanted to use 10 mm swa for the volt drop reasons above and also in case my brother wanted to add which he has now decided to do
He now wants me to wire a outside socket of the radial sockets so means altering the conduit and the singles i already installed and also on the outside a fcu to supply a large decking area with decking spotlightsappox 20 of them and also 4 which will be on a vertical wooden wall at the back of the decking
the house is a TN-C-S system and needs a lot of improvment to the existing wiring and CCUs
Now I know i shouldnt have let him talk me into getting jsut a 6mm lol even though we got 33 metres for ÂŁ80 and the 10mm was more like double
can someone give me advice on best types of lighting to use ELV with transformers thinking 12v and places to buy etc
will the Volt drop be an issue if supplied from the shed either by another seperate SWA to the decking or swa from a external FCU or should i directly supply the decking lights from the house using either another seperate swa or from the conservatory were there is double sockets but these are already spurred of the House ring with a 13 a fcu in the lounge
Sorry its not more detailed but this is a first for me installing decking lighting lol it wasnt invented when i started lol
any help and advice appreciated greatly
cheers
cheers
