Cable Behind Skirting Boards? | Page 2 | on ElectriciansForums
Discuss Cable Behind Skirting Boards? in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
just wandering what the view is on running a 2.5mm radial circuit behind a skirting board when it's fully protected by a new 17th ed. RCD protected CU.
thanks in advance
Neil
Although i do have a quiery with this.. My brother is wanting skirting board lights.. (DONT ASK WHY! lol) but he has a solid floor.. Meaning im going to have to run cable from each light UP and DOWN and UP and DOWN to the ceiling and then to the light.. Thats alot of cable.. and alot of chasing! :p
Any way around this?
Skirting trunking - probably get some nice looking stuff nowadays.
Stick an accessory (ie lights) in there and you have created a safe zone vertically and horizontally so no issue, also the skirting board lights are low voltage. You can even purchase specially designed/constructed skirting for this sole purpose, GOOGLE is your friend :thumbsup
Agree ^^^^
Don't forget you create a safe zone by where you place the accessory, so as long as the cables run to the accessory in the safe zones created its OK.
Hope that makes sense!
it's not a safe zone. 150mm below ceiling is a safe zone. maybe that's where the confusion arises. just look in the regs. there's a pretty diagram, which was also put on a thread a day or so ago.
I recently did a re wire for my brother and found this lurking behind the floorboads, A bit further down It had been missed by a nail by just a few mm [ElectriciansForums.net] Cable Behind Skirting Boards?
Reply to Cable Behind Skirting Boards? in the UK Electrical Forum area at ElectriciansForums.net
Thank you for the speedy response! Have seen them on top of plaster in steel conduit before but guess it's not a common desire to have wires...
With what looks like only 5 circuits you can probably put a little 5 way garage consumer unit in there if money is tight
