why in old houses did they..... | on ElectriciansForums
Discuss why in old houses did they..... in the UK Electrical Forum area at ElectriciansForums.net
Lounge
Fit pendants about a foot from the window I have heard theories over the years be good to get an opinion from someone on here that may have wired one in the 1930' s lol
J
  • [ElectriciansForums.net] why in old houses did they.....
2 things one was to replicate light coming from the window the other was not to cast a shadow as a lot of lights did not have shades more common in bathrooms ie nearer to the window so as not to cast a shadow
No electrical but following the same privacy rule as above,
Another one you don't always see nowadays is doors to rooms were always hung so they hid the view into the room when the door was partly open.
Reply to why in old houses did they..... in the UK Electrical Forum area at ElectriciansForums.net
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
What is the distance from the point outside the house to the shed?
