*** LINE Introduce DIN Rail Terminal Connector Series *** | on ElectriciansForums
Discuss *** LINE Introduce DIN Rail Terminal Connector Series *** in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dan
Staff member
Admin
Mod
Nearly Esteemed
Solutions
Staffordshire
LINE Products Introduce DIN Rail Terminal Connector Series
LINE is please to announce the launch of its DIN Rail Terminal Connector Series. Although the LINE DIN Rail series is of a higher specification (cage spring) that those offered by others, LINE is offering these to forum members at the same price (rail stops, marker cards and end closers will also be provided free with each DIN RAIL Series order).
[ElectriciansForums.net] *** LINE Introduce DIN Rail Terminal Connector Series ***
Please visit the FORUM SHOP @ LINE to order.
Reply to *** LINE Introduce DIN Rail Terminal Connector Series *** in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
EMailed to the forum for you @PCBWay
    • Winner
