ok spot the error | on ElectriciansForums
Discuss ok spot the error in the UK Electrical Forum area at ElectriciansForums.net
N
nickblake
spot the errors one on the earth lable of a consumer unit still trying to figure [ElectriciansForums.net] ok spot the error out the numbering , the other is how scottish power wired an isolator ,not the out going they are tempuary [ElectriciansForums.net] ok spot the error well done scottish power
Is that the serial number of the board?!! And when did they slip that into the harmonised colours...... neutrals now green/yellow????
I heard somewhere that Stevie Wonder had got a new job................ looks like he's working for Scottish Power then!! :grin:
They have used the numbering on the earth / neutral bar to align the tails.
Surely if they are tails then they go from the back to the front, seems likely!
Those numbers must be the bar code that takes you to the website that gives you the link to the download of the numbering system code that translates the numbers to letters and the letters to numbers so that the sequence is correct....
it seems so obvious now!
Reply to ok spot the error in the UK Electrical Forum area at ElectriciansForums.net
Hello, Last year my 30 year old Static Pase convertor stopped working, the 3 phase motor is 0.55KW / 0.74HP and drives a small lathe. When I...
One of those backlight Chinese testers may have helped that’s if the tester didn’t catch fire or electrocute you. LED TV Backlight Tester 12W LED...
2 3 4 5
4K
