M
Maximus Rumpas
Hi,
I would like to ask your advice about how difficult it might be to pull cables through 20 mm plastic conduit. (easy, moderate, hard, impossible)
I am running two separate lines for a cooker and hob in 6 mm2 single core stranded cable. Both runs will follow the same route.
4 meter run from distribution board via 90 degree inspection bent to an inspection box next to soil stack.
Next 2.5 meter run through Bathroom/Kitchen wall to an inspection box under sink (minor set to allow for wall levels)
Then either
4 meter run, chased into wall via 90 degree inspection bend to a third inspection box.
or
4 meter run via 300 mm drop to Floor level - two 90 degree inspection bend to the third inspection box.
Lastly 1.5 meter run to cooker or hob isolation switch.
On completion permanent access to inspection boxes - limited access to 90 degree inspection bends.
Your thoughts please.
Kind regards
Max
Then either
or
Kind regards
Max
