S
serpico4321
Hello All,
I am currently hitting a barrier with regards to the basics of this question. It is for a HND so I may have put this in entirely the wrong forum. Apologies if so.
A 50HZ supply is connected to various given impedance's connected in series and parallel. Calculate the value of the load impedance and the maximum power transfer.
Maximum power transfer I understand is basically the Thevenin/Norton equivalent of Rth. But to acquire Rth surely you nee two values of ohms law?
Though THERE IS NO EMF indicated in the question. Is it possible to simply use the frequency given 50Hz and the impedances to calculate the maximum power?
Any help in the right direction would be vastly appreciated
