Which downlighters?? | Page 2 | on ElectriciansForums
Discuss Which downlighters?? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Supporter
Gloucestershire
I have been asked to install 6 downlights in a customers bedroom. The 3 makes that keep springing out at me are :
LAP, Robus and JCC
I dont like LAP switches/backboxes etc but thats all I know of them.
I intend to only offer fire rated ones but would be grateful for anyones knowledge of those 3 makes of downlighters?
As for bulbs!!! 90p for halogen or £20 for LED!! Thats a massive difference, are the LED's worth it?
Cheers all..
Just thought I'd finish off the thread with what I think of the JCC (fireguard range) lights I used.
BRILLIANT to connect to! Plenty of room to fit 2 (1mm) cables into the little box they supply fitted to the light (with great big terminal blocks screwed in). I didn't need the wago's/choc box/junction boxes I had bought just in case!!
The only small downside was the strength of the springs. They were fine when put up, but i needed to take a couple back down and the springs seemed to weaken considerably (This might be common?) when put back up so I had to improvise a little so the lights fitted snugly against the ceiling.
Overall it was a pleasure fitting them. Thanks to those who recommended..
Are you refering to the JCC3?
[ElectriciansForums.net] Which downlighters??
Was just going to send the picture but cant send unless I write at least 6 words... so I have.
Reply to Which downlighters?? in the UK Electrical Forum area at ElectriciansForums.net
I personally have two Integral Evofire Recessed (low-glare) on trial at home outside the UK; just realized they were, however, made of steel. The...
  • Poll
Hi Folks, I'm looking for downlights that satisfy the following criteria: (1) white bezel; (2) fire-rated; (3) IP65 or above; (4) anti-glare...
I'm not sure on the environmental implications, a good quality integrated fitting will last many years and be more energy efficient than the GU10...
davesparks
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
