I thought most ppl used GCH like me ??
Not round here! - the majority are on liquid gold aka oil, and turn their boilers off from May - October.
like whats your export rate to grid to work out
Irrelevant when deemed.
Discuss Do immersun type devices work in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Thanks for the help see answer in quote aboveGiven that is you heat your hot water cylinder with electric, I thought most ppl used GCH like me ??
If you do use GCH - the benefit could be less but still rewarding, again its all about knowing your systems, your needs and whats possible with your system, especially figs
Domestic export is always based on 50export unless you have an import export meter.
Most people do not.
Then your getting paid export plus any savings you make from using more than 50%
@Worcester renewables.
Thanks I didn't know it was a proportional system .
So it will dump what ever is spare into your system?
Good too know.
work out ultimately your ROI !
If HOWEVER like me you use the vast majority of your generated electric - there is very little left to use elsewhere and this is what I am suggesting.... the more sauvy PV owner would know this by either monitoring devices or by use of PVO for example
Your PV system is giving you a return over 8 - 10 years which you thought was a good investment - so why isn't an ImmerSun type device when it gives the same return?
- - - Updated - - -
Correct, I agree.
Try using the eco-eye Eco-Eye | Real Time Electricity Monitors | UK - it has an RF device and you can link it up through your pc via cosm (ex pachube) to pvoutput.org (Eco-Eye | Real Time Electricity Monitors | Eco-Eye with Microgeneration/Photovoltaic Installations Eco-Eye | Real Time Electricity Monitors | Eco-Eye used with your computer)
This one uses that system above and has an ImmerSun installed - you can wee how it tracks plus when they had breakfast and put the kettle on
One small point we have found....None of the monitoring devices work with Immersun
Reply to Do immersun type devices work in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
