E
Earthstore
What is wrong with a PV system and an export divert unit? (read the many threads to choose) Surely the sums would work out better.
Discuss Solar thermal in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Get him to have biomass
vented or unvented?Need some advice regarding a solar thermal system. To remove existing cylinder is going to be a nightmare, small cupboard and pipes covering the cupboard. So I am thinking of installing separate cylinder and piping the hot water from the solar cylinder into the bottom of the existing cylinder. Any thoughts.
View attachment 18632View attachment 18633Pipes every where
Gavin what is solartwin ?seriously, check out the solartwin / thermatwin panel for that, you'll probably be able to just tap in to the pipework in the loft and stay away from that mess - though you might need to insulate some of the pipework.
ask for a trade account mind
ThermaTwin Solar Panels - DiscreteHeat UKGavin what is solartwin ?
Reply to Solar thermal in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
