Hi chaps,
Well, I have one of them
Fitted it 10 years ago, still working! Till recently. Going green I decided to replace the outside lights
with LED types and splashed out 40 quid. Now, after dusk, the lights come on for 5 seconds and then go off for a couple of minutes and so on. Pretty annoying.
first I suspected the sensor, so I removed it, took it inside and connected it to a lamp (filament) and it is working OK.
I assumed there is a relay inside but now it appears to me that the load of the LEDs is not high enough
to operate the sensor correctly. Do you know any alternatives which are suitable for low loads?:frown2:
Thanks.
Thanks.
