I dont think they should look like that | on ElectriciansForums
Discuss I dont think they should look like that in the UK Electrical Forum area at ElectriciansForums.net
Tim
ESSEX
Doing an eicr in a hotel and the maintanence guy asked if i could take a look at an intermittantly tripping rcd.
Rcd tested fine, so i started disconnecting the fittings for an ir test and found this.
[ElectriciansForums.net] I dont think they should look like that
200mm of kingspan, and unenclosed connector blocks sitting in the kingspan directly above a 50w downlight.
Anyone else had any fun findings this week?
Tim
Tim
At least it's parked between the lines.
And that hr insulation looks brill.
Tim
just this little bit of nonsense going on in a cellar....
looks like a Electrical Trainee board change....
[ElectriciansForums.net] I dont think they should look like that[ElectriciansForums.net] I dont think they should look like that[ElectriciansForums.net] I dont think they should look like that
Reply to I dont think they should look like that in the UK Electrical Forum area at ElectriciansForums.net
Hi Gingerrubix, The fact that your previous Tenant replaced a faulty socket plate which he used for an external EV, raises an eyebrow. Also your...
My thoughts exactly! Snowed under with work at the moment, so might have to pass it on 😬😬
