dtc digital time clock | on ElectriciansForums
Discuss dtc digital time clock in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Dalf
glos
Hi.
Have any of you used these time clock. Have no instructions so wanting to know what I use to connect. Has 1 and 2 at top of time clock. And then 3,4,5 at bottom.
If any of u guys could help then would be great.
  • [ElectriciansForums.net] dtc digital time clock
So connecting it with a photo cell being involved . Would be taking feed an neutral from adapt box and then my s/w to bottom connections?
It looks like there are icons above the numbers showing you what they do and it looks like 4 is the common otherwise as Tel said.
permanent supply to 1 and 2, line supply to 4 and outgoing line from 3 or 5 then on to the photocell, then your light will come on only when the timer is on AND the photocell operates, if that is what you want it to do.
Reply to dtc digital time clock in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It's a room where someone sleeps, so it's a bedroom. Minimum standards were set in the Parker Morris report in around 1963. Anything built after...
how long have you had the oven? Could be that the heating element has blown. Which happens after a long period. Is everything ok on the...
Cbelectrics
C
