Hi All
I've been to do it second fix at the house where the 1st fix has already been done, all cable runs are visible so I've no problem completing it.
1st fix was done about 2 years ago, it's an unlived in project, the electrician at the time has wired 2 way switches for the hall and landing the owner wants to be able to switch hall an landing lights from hall or landing.
I expected to see usual set up of switch wire and 3C&E connecting 2 switches, however at both switches are 2x3C&E with no switch drop at either and all 4 of the 3C&E terminate at ceiling roses also there is a T&E connecting hall to landing rose.
Is this a method I've not seen before because for the life of me I can't figure out how to wire it an I've never seen two lots of 3C&E at the rose!
Any thoughts welcome!
