G
GLENNSPARK
Well......
Take a peek at these pics boys:
The cover was nearly off on this...its a dedicated cooker feed and none of the cables were terminated....yep, its still energised....
Found this CPC out of the earth bar upon pre-board change inspection...turns out theres 55 volts sitting on it....
Theres a mix of class 1 & 2 lighting in here n all...
looks like someone decided the CPC wasn`t needed as there was a `fault`....what a DIMMER.......
