been to look at a job today,customer just bought house a few month ago and they say they have just had a inspection done on the electrics and everything passed ok, as soon as i walked in 3 light switch drops just hanging in mid air with switches and back boxes connected where a wall had been removed, cables entering through back of boxes no grommets and outer insulation stripped to far back so just the insulation on the cables rubbing against metal back box, asked if when they had the inspection had they seen this and answer was yes but nothing said about it, 2.5 ring main running in a open channel in the concrete floor with a connector block joining one of the legs no attempt to put the connector block in an enclosure even though he said it was only temp, apparently his mate is an electrician and as been doing bits on it but hasn't got time now lol, so looks at c/u no periodic inspection and testing label on there even though he said it was a big company what had done the inspection, earthing arrangement is TT single rcd main switch 30mA protecting all circuits, so go to look outside where earth cable seems to run no earth rod or pit in site just decking what looks like it has been down for years so looks like its underneath and not accessible, same again says nothing was mentioned on inspection, so get to the job in hand he says i want 12 down lighters and my cooker connecting up in cellar, cellar just been re-boarded and plastered and painted concrete floor above lol, looks like new 6 mm been put in for cooker no sign of an isolator anywhere for it just a cable straight from c/u to about 6 inch from floor where the cooker is going all newly plastered in, first thought was i was on youv'e been framed just don't understand some people some times, asked to look at the inspection report and said he would have to get it me as it wasn't there lol
