Was putting the big disco car park fittings and the igniter is mounted in fitting at top, isit normal to add capacitor and ballast and bottom of post? Any lights I've done before it's all been built into fitting.
is this normal to come out Of Lucy with live into ballast (bare unit ) mounted in post. Then through capacitor which there is two which are wired in parallel then into igniter then off to lamp
