Need some advice | on ElectriciansForums
Discuss Need some advice in the UK Electrical Forum area at ElectriciansForums.net
Rappid
Wickford, Essex
Had a look at a new build, the house has been knocked down and re-built and now waiting for first fix.
Would I be right in assuming the fuse is rated at 57A, don't fancy pulling that fuse to check
  • [ElectriciansForums.net] Need some advice
Noticed the two singles as well my first thought
Also looks like mr meter man has fitted a new digital meter so why don't they inform DNO about these old heads seems they just pull fuse change meter then go come across a few in London area like the one in pic all with new meters fitted
That is ancient.....
I also note the "use asbestos tube when rewiring"
Thankfully not many of them kicking around these parts....think the hydro dealt with most of them as they do both dno and metering work. Though now I've said that I'm going to come across one of these "lovely" service heads......
What's with the Red and Blue singles?
Red and blue singles is builders handy work. It's 6mm cable running into a CU to provide lighting and power for tools.
Don't know the full story but it was an old bungalow, and when the owner applied to extend it, building control told them they had to knock it down as the existing footings and walls could not take the weight of the new roof.
So they demolished the house, rebuilt it and...remounted that??
I get it - it's a 'listed' head!
Reply to Need some advice in the UK Electrical Forum area at ElectriciansForums.net
If it's buried ducting, have you thought about digging up a section of the buried cable close by, cutting it and pulling in a few extra meters...
It sounds like the original meter was reading incorrectly and octopus aren't keen to admit this as they would probably have to refund you. I...
davesparks
Recommended Sponsor News
Hi everyone,
