Light Fittings for Flat Roof Skylights | on ElectriciansForums
Guest viewing is limited
Discuss Light Fittings for Flat Roof Skylights in the UK Electrical Forum area at ElectriciansForums.net
B
besenzig
Hi
Can anyone suggest what type of light fittings are best suited to illuminate a flat roof skylight.
Customer has had a skylight fitted on a flat roof and at night just looks like a black hole in the ceiling
which she wants illuminated. Presumably some form of up lighters could be used but as I have not done one before
I do not know whats available.
Any help would be much appreciated.
What about one of these fitted upside down?
[ElectriciansForums.net] Light Fittings for Flat Roof Skylights
This could light up a black hole any day! :D
Reply to Light Fittings for Flat Roof Skylights in the UK Electrical Forum area at ElectriciansForums.net
Thanks for the input guys. Lighting track is out of the question. The routing (h section guirders and angle iron) means that swa cable clipped...
I recommend the Manrose Humidistat timer: Humidity Sensors for fans -...
