emergency lighting | on ElectriciansForums
Discuss emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
F
foghorn
hi guys
have a project coming up to do emergency lights and regular lights also with ceiling mounted pir detectors al to be on the same circuit corridor with a x2 pir detectors and x1 emergency light and standard lights and offices with standard lights and emergency. scratching my head how to go about wiring this any pointers much appreciated also key switch for testing
many thanks
When your running lighting with PIR`s ....its happy days, you have a nice permanent live supply to the pirs and em lighting.....good idea is to run 3 core throughout the installation...tapping off permanent live, switch live etc....as you go,
I see would it not be a struggle to have 2 sets of 3 core to terminate in the pirs so wire to pir then to key switch back to emergency light then to non emergency light and so on is this correct in what im thinking.thx
no think abaut it.....2 core off db L & N, into combined light switch and test switch.....3 core from light switch 1 perm live, one switched, one neutral.....now along this 3 core, you can install any number of lights, any number of pirs, and any number of em lights.
hi guys
many thanks
  • [ElectriciansForums.net] emergency lighting
lol like the picture I want to install x2 pir sensors to activate lights as the corridor is long within these lights will also be an emergency light sorry if I did not explain very well.
Reply to emergency lighting in the UK Electrical Forum area at ElectriciansForums.net
The company Liteplan do replacement modules: Liteplan – The UK's largest emergency lighting component supplier. - https://www.liteplan.com/ This...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
Recommended Sponsor News
Hi everyone,
