cable supports/binders... whatever they're called? | on ElectriciansForums
Discuss cable supports/binders... whatever they're called? in the Electrical Tools and Products area at ElectriciansForums.net
Having complete complete brain fade here...
what are the wire twisty things called the DNO use to support the concentric cables? and are they available to the trade?
I have a job coming up that needs a 16mm concentric span overhead. can anyone point me in the right direction?
no. not catenary wire to support the whole length, the drawn wire twists that the DNOs use to fix the cable at the end and wrap around the cable and china insulator?
  • [ElectriciansForums.net] cable supports/binders... whatever they're called?
yes. You'll see the DNO use them on overhead service cables.
Ive used several in the past, but my 'supplier' has retired from the DNO :)
Reply to cable supports/binders... whatever they're called? in the Electrical Tools and Products area at ElectriciansForums.net
Sounds more positive.
Back to the Men's Shed today to complete the installation of the 4 LED battens in the attic. These were a joy to fit, having screwed the units to...
