stop start | on ElectriciansForums
Discuss stop start in the UK Electrical Forum area at ElectriciansForums.net
`Carlisle
As an apprentice, I was learning the other week about stop start wiring through a contactor, can someone please help as basic as possible so I can have a good understanding of it. cheers
A diagram is the best way to visualise things...
One side of the contactors coil is usually permanently connected and the other side goes through the control circuit first, stop buttons have priority and over any start commands so when you take a supply to the retaining contact it comes of the control circuit after any stop buttons or overloads etc and usually is taken from the input side of the start button.
The output side of the start button goes direct to the coil so pulling the contactor in when you press the button, this would drop back out when you let go so you have a retaining contact that pulls in at same time and the output of this retaining contact also goes to the coil with the startt button output.
Now once the retaining contact is in it is as discussed energised from the control circuit at a point passed all stop commands so pressing any stop button will loose the power through the retaining contact to the coil dropping the contact out.
PM me with your email, and i will send you a wiring diagram and explanation. I have problems trying to post stuff like this on here.
Cheers..............Howard
This is a picture I found I had showing a method of switching a contactor as a stop start.
Looking at it, it does not seem to be a very good way of wiring the circuit but it does demonstrate the principle explained by Darkwood above.
This is intended to switch on and latch on a contactor via a start button, this then operates another contactor to operate a 3 phase heater.
[ElectriciansForums.net] stop start
Just realised why the circuit looks odd, I drew it!
I'm not sure why you wouldn't just use a single contactor with a normally open auxiliary contact. Also a mixture of permanent supply and switched supply on the load side of the left hand contactor is a bit unorthodox.
OK now what can I pick holes in on your diagram?:thinking:
Hmm... yeah OK not bad!
The OP did not say it was for a motor though! (I think I am clutching at straws here)
I ripped mine off google images so was cheating a little, so far I get 0/10 for effort giving you the winning hand back.
Arrh! Tony's arrived with his famous library of wiring diagrams ....was starting to worry for a minute!
Reply to stop start in the UK Electrical Forum area at ElectriciansForums.net
Sorry for the late reply I found it very difficult to find work but I’m not sure if this was down to Covid and all the lock downs happening just...
I've seen a few posts here which tend to suggest that wiring in a motorhome (or caravan) wouldn't be subject to normal inspection rules, but even...
And exciting when that Hager AFDD finally tripped 😂
nicebutdim
N
I would agree that the motor is by far the best part to replace. if it is powered and not turning then it is broken. Keep it simple!
thanks for the replies. Appreciate it.
