Discuss stop start in the UK Electrical Forum area at ElectriciansForums.net
As an apprentice, I was learning the other week about stop start wiring through a contactor, can someone please help as basic as possible so I can have a good understanding of it. cheers
True..I'm not sure why you wouldn't just use a single contactor with a normally open auxiliary contact. Also a mixture of permanent supply and switched supply on the load side of the left hand contactor is a bit unorthodox.
Now all you need is to stop using switch symbols and use push botton symbols ...:thinking: soz Rich just been annoyingly picky 'whistle~~~~'Is this better and clearer?
I ripped mine off google images so was cheating a little, so far I get 0/10 for effort giving you the winning hand back.OK now what can I pick holes in on your diagram?:thinking:
Hmm... yeah OK not bad!
The OP did not say it was for a motor though! (I think I am clutching at straws here)
Reply to stop start in the UK Electrical Forum area at ElectriciansForums.net
