S
spraffers
hi guys, im fitting a 10.8kw mira sport max, i have read various threads on this and i think 10mm cable is suffice but the problem is at the moment my cable runs into the old cooker fuse on an old fusebox which is 30a.
I know i need an rcd fitted, it is wire through an isolator switch.
Can you please advise what i need to fit? eg rcd etc
