Discuss Light switch conversion bracket in the UK Electrical Forum area at ElectriciansForums.net
can you not get some conduit box lids and use 4mm pins and nuts?Anyone know where I can source the attached (imperial lighting conduit box converter) or a modern equivalent?
Unfortunately not. I had been told that this would do the trick, but unfortunately it is too wide to fit into the BESA box ....
"MK CONVERSION BRACKET COMPLETE WITH EARTH TERMINAL.Converts 25mm deep flush switch boxes with 42mm fixing centres to accommodate plateswitches with 60.3mm fixing centres, 3840 ZIC"
bassically box lid with 4mm pins to fix a 12mm surface box.Run that by me? Not sure what you mean! :thinking:
Yup, it is!I take it the box is sunk in wall.? (cast box)
i'd have made one by now. bit of 16 gauge steel, drill, hammer, cold chisel, file.
and a lot of muscle if trying to cut 16 gauge with tin snips.
Reply to Light switch conversion bracket in the UK Electrical Forum area at ElectriciansForums.net
