today I was doing some maintenance work on a motor and discovered the motor had no earth at the motor terminal. The motor terminal box is plastic but surely it should still have an earth is this correct? And if so should I run a new 4 core a swa!
The reson why I’m asking is I was told just to reconnect the motor but this just doesn’t seem correct.
Thanks for your help in advance
