0.5mm T&E cable now available. | on ElectriciansForums
Discuss 0.5mm T&E cable now available. in the Lighting Forum area at ElectriciansForums.net
The 2A MCB part backfired slightly, because you can get them already.
What about their E.
And 0.5mm taking 8 amps max current. :)
0.5mm cable takes a max current of 3A. Having 50 5W LEDs in house is 250 watts. That is around 1 amp. So 0.5mm will do a very big house. So not that much of a joke.
This reminds of a few years when I saw a lighting circuit in a one bedroom flat wired with 0.5mm flex, as all lights were LED. The guy got a reel super cheap or for nothing. He used a 2A MCB. A neat job. He said to wire up lighting switch backboxes it was super easy as only thin wires, and that 0.20 mm² to 4.0 mm² is what lever Wagos take. He use these in the backboxes.
This reminds of a few years when I saw a lighting circuit in a one bedroom flat wired with 0.5mm flex, as all lights were LED. The guy got a reel super cheap or for nothing. He used a 2A MCB. A neat job. He said to wire up lighting switch backboxes it was super easy as only thin wires and that 0.20 mm² to 4.0 mm² of what lever Wagos take. He use these in the back boxes.
Sounds like a nightmare house for whoever has it next 😀
He only did the lighting circuit. It worked well and a neat job as well. I only saw the CU. It worked and was safe. He did his homework on safety, the max amps loading of the cable, etc. No way would the cable overload using LEDs and 2A MCB. I never saw any bodged DIY work in the house.
Now I'm really confused!!!
I just watched the video. It all makes perfect sense and sounds great. Then...... right at the end the guys mention April fools!!
Now I don't know what to think 😅
You think @Megawatt is reading this and going “wtf is April fools????”
A uniquely British tradition I think… although research shows it celebrated in other European countries.
Up here…. It is also known as “Hunt The Gowk”
I know what the phrase April fools joke means. Y’all have an awesome weekend and I appreciate all of you. 😂
They did a good job. Where did they get the 0.5mm T&E? It was obviously thinner than the 1.00mm cable.
The points is, is that 0.5mm and a 2A MCB or RCBO (which are available) would be perfectly safe using 0.5mm cable. The max current draw of 0.5mm is approx 3A. 50 LEDs consumes 150 watts. So well within safety limits.
I would not go less than 1.00mm simply because that is the lowest T&E available.
Reply to 0.5mm T&E cable now available. in the Lighting Forum area at ElectriciansForums.net
Does it really actually need earth sleeving inside the tube? I know it feels a bit bodgy but what's going to happen and isn't an unbroken...
Job interview View: https://www.youtube.com/watch?v=uYKD1j5jEvs
