solgen
Does anyone have an opinion on the route to go for a 50kW system that either has 1 large central inverter or many smaller string inverters? My immediate thoughts are:
1. If some of the panels or inverters drop out then at least remaining parts of array will produce energy for a system that uses string inverters.
2. Easier to locate string inverters by placing them on the PV mounting poles.
3. Central inverter will require some heavy weight kit to locate it.
4. Central inverter out of doors in a field will require a purpose built building to locate it in.
Does anyone have a preferred solution for a 50kW using multiple inverters or a central inverter i would appreciate your thoughts
