Hi all, my first post and i'm only starting doing domestic work after mainly industrial so please bear with me!
I've been asked to re-wire a building that is a flat above a shop. the new owner wants to turn it into a lock-up shop and have the flat seperate. There is currently 2 old cu's which need replacing, one for the shop and one for the flat but both are fed from 1 meter which i think is a smart meter. A few questions -
1. Does he have to have a seperate meter for each cu as the property is in effect going to be split in 2?
I guess its a common question on here but i need to cut the tags to replace the tails as they are in a woeful state and to resite the cu's, so
2. Can i cut them and put the new tails in to the new cu's and then who do I have to inform to re-seal it?
3. Am i right in my understanding that the tails can only be a max of 3 meters long or is that dependant on the suppliers?
Many thanks
Many thanks
