1 string or 2? | on ElectriciansForums
Discuss 1 string or 2? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
DomB
Chaps, if the inverter can take the voltage and wattage etc of an array as 1 string what are the reasons other than differences in panel shading / orientation / pitch to split an array into more than 1 string?
Thanks!
Not many reasons to split - inverters work better with the higher voltages, generally.
You do start hitting the limits of what the standard ranges of dc isolators will cope with though.
Regards
Bruce
no problem with isolators to 1000vdc limit of most inverter mppt ranges
string output only as good as its weakeast link or module
snow , leaves , bird **** , shading
sometimes smaller strings are better
Reply to 1 string or 2? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi all, This may is a little odd and may take some getting your head around but here goes... I measured around half the load current on two DC...
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
