M
Marston
ImageShack® - Online Photo and Video Hosting
The lighting circuit im trying to fix looks like the image above, apart from the bulb has 2 earths coming from it but that shouldnt make a difference. Also at the dimmer switch the switch is in L2 and doesnt work in L1?
I took it apart as the dimmer switch only turns the light on and off.
When i first looked at the wiring at the bulb all 3 red wires were on the same side of the connector block with nothing on the other side, 2 blacks one side and N i think on the other side also 1 black one side L on the other. Which obviously looks nothing like the picture.
Also the person who previously did the work hadnt labelled any of the 3 t&e so i dont know what is the supply to the light, supply to the next light and the t&e that goes to the dimmer switch (dont have continuity tester and there are no labels at the DB and i know that its on the same radial as the hallway and front room and the wiring is complete mess at DB)
So i just thought by process of elimination i would get it to work. Which involved lots of possibly variations so lots tests (1 with 2 in 3 out(L1 then L2). 1 with 3 in 2 out etc(L1 then L2) etc).
After doing all of them it wasn't working. So if anyone can understand my problem and can help it would be much appreciated? thanks
