G
Garyledger
From the consumer unit i've ran a 3-core cable to the light, and then from the light to the switch which is a 2 way switch, where does the live and neutral go into l1,l2, common terminals?
I know if the switch was 1st then the lives would go through common and L1 and the neutrals would go into a terminal strip butI cant work out what to do with the switch after the light rather than before....
help would be greatly appreciated thanks
