The mechanical strength is an obvious test, it's the electrical soundness that is harder to test. You need a ductor or similar high current milliohmmeter to test it properly
if it is mechanically solid all the way around then it will be fine.
the lugs are steel so technically reduce ccc if your being picky.
No it won't, it must be electrically sound as well as mechanically sound!
Where on earth are you getting steel lugs from? Lugs for copper cables should be tinned copper
they look silver, i just ask for lugs at the wholesaler (never seen any copper on them but thats just on the bigger sizes e.g. 50mm
Yep, all common lugs will be tinned copper.
just googled it, you learn something new everyday
How did you think the solder takes to them if they were steel? Or don't they teach sweating lugs anymore?
just tried them out today on some 16mm earth i had in the garage and there good.
crimped one on its own without a cable inside and it crimps uniform inside as well
Out of curiosity (I don't need to buy one btw but it may help others decide before buying one )
What's the build quality like?
The one I saw looked the same, bit of the usual wear and tear on the finish which wasn't the best,
but like I said before it seemed ok just didn't crimp quite as well as the cembre one,
Can you do a review after a few months of use ie is it ok or has it failed at some point
will do, i won't really use it a great deal but the build quality seems good.
the dies dont quite lock solid but when you locate the lug in the jaws the play makes it easier to locate it and then it works perfectly.
its not really a problem but only time will tell, it doesnt seem likely it will slide when you try to crimp the button to allow the dies to spin pushes a 3mm plate back to allow the dies to spin.
ill get some close up shots tomorrow but im quite impressed especially with the price
The reason for the play in the dies I would think is to ensure its crimped equally around the lug ,ie the dies meet correctly
If they were locked in position the bottom would be crimped more so than the upper side, like if you tried crimping a ferrule with pliers (seen it a few times!) the bottom is cut in deep the upper side hardly touched
I like to tape over my lugs up to cable, brown, blue, grey, y/g,black just always have done.
You need to test them properly.
Accurately measure the resistance of exactly 1M of conductor, preferably using something like a ductor/milliohmmeter with a reasonable test current if you have access to it or else pass a current of say 25A through it and measure the volt drop to get the resistance. Then cut the conductor and join it with a through crimp using that tool. Then re measure the resistance of 1M including the joint using the same tester/method.
The results should be substantially the same, if not then you have a high resistance joint.
You can calculate the heating effects of this increase in resistance using the current that the cable is likely to be used to carry. for example if you use 16mm conductor and the joint adds 2 ohms resistance to the conductor your heating effect with 63A current would be
P = I[SUP]2[/SUP]R
P = (63Ax63A)x2ohm
P = 7938W
P = 7,9kW
P = I[SUP]2[/SUP]R
P = (63Ax63A)x2ohm
P = 7938W
P = 7,9kW
i went with tonys method.
chopped through the middle of the crimp and i would not recommend them, the crimp isnt tight on the cable all the way around
the crimp should be solid on the copper all the way on the outside at least from the type of crimper it is
Thanks for sharing the info,pics, and result.
I'm looking at having to buy a crimper today or tomorrow, and was hoping this cheap option would work well.
I would be very interested to see what difference the £65 CK T3676 makes.
I'm guessing no one is going to crimp a lug and cut it through to show LOL.
forget that ck one. £20 on tlc for a crimper from swa
Ha ha I suppose I could get the CK one from Screwfix - do a test connection, if it ain't pucker I can take it back for a full refund. :biggrin:
As a trainee do you really need to be buying your own? You employer should be providing specialist tools like this
Depends on who you work for dave ... I had a reet tight un of a boss, I had to provide all my own tools and if I didn't have them then I was warned, power tools were supplied and test equipment though (not that we used em much in the day)..:innocent:
I don’t have an employer, I work for 2 agencies.
Sometimes you get stick/ or sarcasm for not having tools, other times I can use what’s provided.
Since I want to be SE down the line, I see tools as an investment. I don’t have to save 45 quid on this tool but I don’t want to be a mug paying for a brand if there’s alternatives that work.
I’ve been suitably scared by tales of fires from poor connections so want to do the right thing.
Thanks ! I’m still dithering, the TLC ones look the same as the CK :teeth_smile:
Davesparks
I want the crimpers for what I’ve been discussing with your good self and others over in trainee section.:smile5:
USA
United States of America
Manufacturer / Distributor / Supplier / Inventor - etc
10-25mm crimper
Electrical Tools and Products
Thread Tags
shanky887614,
shanky887614,
