So do all domestic lighting circuits have to be 10 amp now?
only because you can't be arsed to mark the switch wire. LOL.For some reason I always use 1mm for switch drops. Don't know why, just the way do it.
hotel im working in has just had a visit from someone to look at their energyefficiency and any improvements that can be made His first thing mentioned was my fav things HALERS LED for replacing halogens and also the 2x26w thorn chalice type fitting now has an LED equivelent He said they also mention in passing on the report how LEDs pull less current than halogens hence create less hot spots in trunking,conduit systems
I can't see you getting a shower on a lighting circuit unless you wired your lights in 6.0mm2. There are those who may try it.....hi there just wondering any calculations for working out cable size. so example i have a 9.6kw shower what breaker and cable size do i have to use?
also with wired in smoke detectors can they be wired say off a socket circuit or a fused spur in use or does it have to have its own circuit?
thanks
same post on a different thread, you said you were competent. how can that be if you don't know the basics af calculating cable size from load and length of run?hi there just wondering any calculations for working out cable size. so example i have a 9.6kw shower what breaker and cable size do i have to use?
thanks
harsh mate i only wanted advice! i am competent in electrics i just havent done certain things yet like that.. i know how to work out fuse rating for say the heater but i jsut wanted to calculation for the cable size id personally go for a 10mm cable for that 9.6kw shower. also with the smoke detector i just wondered if your aloud to run if off another supply say a fused spur? i have it on its own circuit anyway im just asking the question, thats what this site is for is it not!?
thanks
